Concrete Code
Concrete Code
Our company is checking a roof design and tank design. The tank stores a liquid at 250 degrees Fahrenheit. Is there a ACI code for design. Can concrete be used in this scenario?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Concrete Code
Does the tank have an interior coating? If so, what is it?
RE: Concrete Code
Excellent points.
RE: Concrete Code
RE: Concrete Code
RE: Concrete Code
As a thought here, what elements does sulfur have an affinity for other than oxygen? Is there anything in the concrete matrix that sulfur likes to put it a different way/
Mike McCann
MMC Engineering
RE: Concrete Code
Coat the inside.
Not sure which code, other than building code would apply to this one.
RE: Concrete Code
Mike McCann
MMC Engineering
RE: Concrete Code
ACI 350 "Code Requirements for Environmental Engineering Concrete Structures" Section 4.3 "Sulfate Exposures"
ACI 350.2R "Concrete Structures for Containment of Hazardous Materials" Chapter 5 "Liners and Coatings"
ACI 350.3 "Seismic Design of Liquid Containing Conrete Structures"
ACI 350.4 "Design Considerations for Environmental Engineering Concrete Structures" Section 4.2 "Expansion and Contaction Conditions"
RE: Concrete Code
RE: Concrete Code
RE: Concrete Code
Mike McCann
MMC Engineering
RE: Concrete Code
Concrete is appriopriate for this type of containment. A big concern for us was bending moments in the (thick) walls due to temp gradient through the wall. (250 deg liquid sulfur inside face, moist soil outside = large through-thickness gradient = substantial bending moments in walls.) We used some sections of the aci standard for nuclear facilities, there was one section that applied to this. I forget the standard number thouigh.
On one small installation, we fixed this by applying rigid foam insuation blocks to the outside of walls with adhesive (I forget the speicif product and adhesive), then wrapped this up like a christmas package with neoprene sheets to waterproof it. (Yes the neoprene wend down first, then the foam blocks under teh base slab, we just folded the neoprene sheets up around the sides & sealed the jonts.) On all the other pits, they were much larger, we used no insulation.
Also be sure to consider the effects of overall expansion & reinforce accordingly. Remember, it will get hot and it will expand, you cant prevent that. (on one installatino we had two large pits, 20 apart with a plant roaway in between. I talked to the geotech and asked about two pits expanding toward each other, what effect would that have on the backfill between. He studied that and recommended a lower level of compaction for fill between that would allow lthe pits to expand & still allow us to build the roadway.)
I had a supervisor there who related a story about an old plant with above-ground sulfur tanks. For those, he said the sulphur pushed through cracks and it cooled and solidified near the outside face of walls, effectively sealing it off. Perhaps cracks don't cause problems.
I did all this back in the '80's, but I don't recall any difficult environmental issues for those. But looking back, I cannot understand why that didn't become a big issue.
my 2cents worth.
chichuck
