3C+ N Impedances
3C+ N Impedances
I have values for 3C Rw90 cable , is there simple method to calculte impedances ( Positive & Zero) for 3C+N ?
2) if I have positive impedances , what s the relation between Z+ and Z0?
3) How about 3C+N + a bre ground wire
I wish it was a simple program out there with all these information, I didn''t need to look around all the time to get this data!!
RE: 3C+ N Impedances
For typical values, see the reference in thread238-241284: X and R Values
Alan
"It's always fun to do the impossible." - Walt Disney
IEEE 141 for
500 MCM Cable
in EMT
Z+= 0.0276+J0.0373
Z0=0.0438+J0.0999
per 1000ft/ohm
Insulation type : PVC
Insulation class: THHN
Nexans Cable Manufacturer
500 MCM Cable
in EMT
Z+= 0.0219+J0.0270
Z0=0.1844+J0.0326
per 1000ft/ohm
Insulation type : XLPE
There is big difference in Z0 values , I am wondering if anyone has experience calculating this values?
The manufacturer's data may not be considering a ground wire within the EMT.
Does everybody design an excel spread sheet with formulas and calculate these values?
In most cases, the analysis software being used will have this data in its database.
"The more the universe seems comprehensible, the more it also seems pointless." -- Steven Weinberg
do you calculate cable impedances using available formulas?
SKM suggests impedances , but it greatly varies with Nexcan's suggested values!!!
