Debarking machine for small diameter posts
In 2002 Bahamaman started thread 50-32674 asking for tips on a debarking machine for small diameter branches.  I want to know if he solved his problem.  I also need a machine to debark posts of quinine trees with diameters from 5" to 2 1/2".
RE: Debarking machine for small diameter posts
Would it be cheaper to use local labor to strip the logs and branches manually of your cinchona?  Provide an economic upswing to them, so to speak?  Spent a lot of time in the Philippines in southern Mindanao where only the largest ag operations are using mechanized methods.  It's unbelievable what human labor can accomplish, and if you pay them slightly higher than the going rate and treat them with decency and respect, you'll have near 100% reliability.
Ornerynorsk:  thanks for the suggestion.  That is precisely what we have been doing for 60 years. Changes in the agro-economy result in scarcer manual labor.  If my harvest starts late, they all leave to work on the sugarcane and coffee harvests which start earlier.  Besides, socialist government policies make it inconvenient to have a large labor force on payroll.  I need to explore mechanization to improve the bottom line.
Treefarmer,
Try a google search for "post peeler". I saw several commercially built unit and at least one set of plans.
Griffy
Griffy, you are the best!!  I had spent hours googling "log debarkers" and other such terms, with no good results.  Already found a wealth of information and plans with your tip.  Aleady requested prices from a used sawmill equipmment dealer.  Thanks alot.  Lucy.
a good handbook of library ejournal list
Do you know how to find out database quickly without entering so many university libraries and search the web again and again? Do you know what databases does a library have? You will recommend google search engine, but does it provide you enough and precise information? No!So we made up this handbook for you guys as an index of library resource menu, for you to get to any database or journal without entering lots of university librares.
here is the handbook!
You can download the handbook here
http://ifile.it/pu29h60
http://www.brsbox.com/filebox/down/f...d1d3903442264f
you can go to http://www.passfans.com/forum userid=your userid get more information
