APDL: Measuring distances and moving lines by this value
Hi all,
I am writing an APDL code to model a structure, and one of the steps involves measuring the distance between two defined keypoints, and subsequently moving different lines (not attached to these keypoints) by the vertical distance measured.
I know the KDIST command displays the distance between the two keypoints, however I'd like to create a script that takes this value and then moves certain lines by this distance!
I hope this is clear... Thanks very much
RE: APDL: Measuring distances and moving lines by this value
