A roll center based question...
To give an example of the knowledge I am after Ill make a theoretical example and ask what the effects might be. You have a 4 wheeled vehicle that has a monoshock arrangement front and rear. The front axle controls the roll rates and roll damping and obviously also has a spring and damper for pitch. The rear axle has no roll springs or damper only a spring and damper for pitch. Theoretically this should have similar effects to a three wheeled vehicle, with two front tires controling roll and a single rear which cannot control roll or in this case a 4 wheeled vehicle with evenly loaded rear wheels no matter the lateral load, correct? Then you throw in the roll centers. Assume the front is where ever, but the rear is above ground. Will the rear tires now have uneven loading under lateral acceleration?
RE: A roll center based question...
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
