If you don't like the Strut-and-tie model
If I don't have to use the Strut-and-tie model for analyzing the corbel in the attached sketch, can I design the corbel by:
1- Calculate bending moment about the C.L. of line 2 as V.eh+H.ev
2- Calculate shear at line 1,
3- provide main tension steel to resist the bending moment,
4- provide ties so that the shear friction capacity at line 1 is grater than the shear force,
5- shear friction capacity is only provided by the ties because shear plane is parallel to force or, do we have to account for the main tension steel also to resist shear?
RE: If you don't like the Strut-and-tie model
Thanks. I am familiar with ACI. Here in Canada, the CSA A23.3 uses the strut and tie model in analyzing corbels.
In my previous post I meant to say " I am NOT familiar with ACI". Thanks
When I am doing a strut and tie model for problems solved in reference books including our Concrete Design Handbook, my models are not the same as those in the books. Even using TEDDS, TEDDS' model is different from the books, the forces are sometimes 25% different. That is why I am looking for a (closed-form solution)that not two engineers will disagree on.
In general, your approach is correct. If you can borrow a copy of ACI 318-xx (two digits indicating year it is in effect), "Building Code requirement for Structural Concrete and Commentary". Pay attention to Ch.11.9, "Special Provisions for Brackets and Corbels". From your standing, you will learn it in no time.
Corbels have been the source of a lot of failures, and are one element where conservatism should be the norm. For the reinforcement, think anchorage, anchorage, anchorage.
In your sketch, the load is getting close to the edge. Corbels are usually loaded at about the centre. If the top corner cracks, there is not much to prevent catastrophic collapse.
Hokie's right.
Canada has long before the US in adopting the strut-tie method in the concrete code (in the early 90s?). And it is there to stay.
I have limited exposure to this method, however, the concept is sound (through mechanical means rather purely relies on experimental studies), and I knew manys claim the freedom in constructing the truss model, and the simplicity of use after you have mastered the constraints.
Go for it, because you couldn't avoid.
http://
