Chemical Reaction
Chemical Reaction
I am in need of the following; I will mix two substances which are in separate chambers, and in fluid state up to 200°C preferrably. When the two substances come together they will produce gas at high pressure. I want the reaction to produce at least 20-30 bar. What limitations are there for temperature? which options do I have? Also, the chemaicals or substances must not be explosive or very toxic, that will require precations e.g. offshore or in a helicopter. The reaction must not produce very high temperature, the reaction can therefore go very slowly...
Anyone up for the challenge?
RE: Chemical Reaction
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
