Excel in draft enviroment
Can anyone explain why my excel table goes out of scale when I modify it in the draft enviroment in SE. I am using SE V10 and have patch version 5.
RE: Excel in draft enviroment
The latest patch for V10 is Update 8 although the
update 8 notes do not say anything regarding your
problem, perhaps update 6 or 7 addressed this issue?
Its not too stable using Excel in SE as some PC setups cope better than other I have found.
I have been told this is due to slight variations in software 'builds'
Basically Excel dont paste in too good !
Milkboy
To place it on a draft and have it editable (add rows or columns) later, you must create a excel file on disk. Use the insert object from file command, place it either linked or not. If it is not linked, you can delete the file from disk if not needed.
Both Insert Object New and Copy and Paste will paste the current data or the selected data on the page, but you will not be able to add rows or columns later.
