Suppliers for Mueller Valve Seals
We have three Mueller 60" Lineseal III Butterfly Valves in our cooling tower.  Recently, we were informed that we could not longer obtain the seal and bolt kits for these valves from Mueller as they no longer make the valves.  The bolt kits are a lower priority, but we need the seals for our next overhaul as it is impossible to replace all three valves at this time.
Does anyone know of anywhere else to obtain the rubber seals and the bolt kits for these valves or a company other than Mueller that makes seals that will fit these valves?
Thanks.
rstock
