Cul de sac radius
Cul de sac radius
Can anybody point me towards the best way to set the proper radius for a cul-de-sac in Map 3d? I just need to define it so that it shows up as the right outline. Is this something that is changed in the GIS data, or do I need to go and draw this in for each ocurrence in the map?
I'm just starting out with fiddling around in here, so I'm not entirely familiar with the product yet.
RE: Cul de sac radius
Thanks.
Right now I'm using Map 3D because it deals with the data in a way that I like better than some other products.
I'm working with some GIS data that I got from the local county. I want to know if it's possible to tell Autocad that certain polyline features are actually cul-de-sac's, and have it render them with a certain style when I plot.
Although, it's starting to look like I might have to convert the features to geometry and draw in the detail I want.
Sorry, I'm very new to this.
As I said,I don't use Map 3D, however, being an Autodesk drawing program, I am confident that you can make Blocks or Groups.
Thanks for your time.
