multiple lines in the custom properties?
In my custom properties there is a Designer field. Sometimes one designer is required to be entered below another. What is the symbol to use to add an extra line below? I thought it was the carriage return symbol between names but I can't seem to make that work.
Thanks in advance.
RE: multiple lines in the custom properties?
Oddball workaround:
Type your text including line breaks into Notepad.  Copy and paste text into your custom property.
I use alt+0010.
I use alt+0010.  How do you enter this??
I can't get the second method to work
You need to type the numbers on the number pad of your keyboard while holding <alt> down.
Thank you.
