Ramp Vertical Load Distribution
I have a ramp in my model, but I cannot get it to distribute the loads to the supporting beams. It only distributes to the columns. For just a floor membrane element I can get it to transfer the loads properly to the beams but not for ramps. How can I accomplish this?
RE: Ramp Vertical Load Distribution
Mesh the ramp element in order to get the loads to the supporting beam. Make sure that you mesh it only perpendicular to the supporting beams and not parallel. It should be one element spanning between supporting beams.
