Intelligent pigging - minimum velocity?
Hi
I am doing a study on intelligent pigging. We are laying a new 22" pipeline and tying into an existing line with a Wye piece.
I line will need pigging to determine corrosion loss during its life
Towards the end of field life, velocities of oil are going to be very low (0.1 m/s or less)
Is there a minimum velocity that an intelligent (MFL) pig can run?
RE: Intelligent pigging - minimum velocity?
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
For liquid line, to achieve high pressure/velocity you could use water [off course treated and inhibited] with additional pump.
The IP vendors data sheets will provide the tool specific pressure/velocities.
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit www.narendranath.itgo.com.
this is the information I have also. the reason why I ask the question is because I believe the minimum speed is not due to the Magnetic Flux Leakage energising the line, but rather the odeometer on the pig itself.
I have spoken to one vendor and they have said that MFL is good for 0-5m/s.
now all I need is someone to back that information up
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Slow speed is not a concern with the newer Hall Effect Tools, it's battery life that would be a problem for extreemly long duration runs. There are ways to extend battery life if necessary.
William
William G. Callahan P.Eng.
Pipeline Management Group
Baker Hughes
