High Speed Bearing,
High Speed Bearing,
I tried a Bronze filled PTFE bearing/wearring but because the speed is 600 FPM the bearing lasted only 15 minutes. The PTFE basically melted and disappeared leaving only the bronze behind.
What bearing material should I try?
Shaft is 3.5 inch in diameter, bearing cross-section is .100", bearing is split.
Jimmy
Jimmy
RE: High Speed Bearing,
