Load an APDL macro in ANSYS
Hi, I am doing some research in fatigue crack modeling. I am using ansys and Matlab interface. But now I have a problem i can't load a .inp file on ansys, when the the solution is done for example.
What I'am doing now it's save de job em .db close ansys and them laod a new .inp file in which I load the information of the .db file, and them what i want to do.
So I want to improve this process i don't want to save and open the job again i want to load the information that i have in apdl without starting ansys again.
I look forward to hearing from you soon,
Best wishes Bruno Serrano
RE: Load an APDL macro in ANSYS
What i understand u can use "Clear and start new" option .. i forgot where it is in the menu :) .. oops!!
It clears all the data in memory (in simple refresh ANSYS) so u dont have to restart .
My APDL files always start with
finish
/clear
! and then the standard parameters:
*afun,rad
pi=4*atan(1)
*afun,deg
! and then a convenience button
*abbr,start,/INPUT,'input','inp',,, 1
