Help on designing a pressurized liquid discharger
Dears,
Iam on the process of conceiving a liquid dispensor, capable of discharging liquid from a barrel using nitrogen pressure.
I would like to get some idea and tips on this concepts and models with engg design.
pls reply if u got any ideas.
Jon
RE: Help on designing a pressurized liquid discharger
Jon,
You are a bit late, this kind of equipment has been conceived long ago;- if you can use the internet, you buy one already designed, perfected, fabricated, you don't need to re-invent the wheel. It will be a lot cheaper for you, plus the benefit of not tiring your imagination to invent something already done. However, if you are still willing to get those ideas you mentioned, I could give you a hand where you can buy plans already fully developed for your use, including fabrication drawings.
Cheers,
gr2vessels
google beer tap system, if you are doing Guines, it uses N2, otherwise, CO2 is used.
Yeah butdo you still get effervescence in your beer with N2?
Guines nitro cans (yummy) or on tap, the N2 makes a smooth creamy head as it comes out of solution easily.
