Use of UBC load generator for Seismic Load in Mat analysis
Hi !!
I'm using STAAD for analysis & design of a plant supported on a mat.
I've modeled the mat along with the structure in a single file.
I'm using UBC LOAD GENERATOR (1997) for Seismic Loads.
I've a problem...
While assigning loads to various joints, the LOAD GENERATOR takes into consideration the self weight of the mat too.
It results in very heavy loads applied to joints. How can i get over this problem??
Is there a specific way to consider the self weight of super structure alone
Arun.
I've a problem...
Arun.
RE: Use of UBC load generator for Seismic Load in Mat analysis
You can then manually input the base shear values back into your original model with the mat.
