Good software for mechanical calculations
can you tell me which software are you using for mechanical calculations? I'm interested in good software for mechanical calculation of heat exchangers.
Thank you in advance.
RE: Good software for mechanical calculations
If so, I don't suggest going that way.
Fe
It will very much depend on what KIND of heat exchangers you need to design.
Mike
David
Fe
Tobalcane
"If you avoid failure, you also avoid success."
And of course you'd have to go back and reprogram everything every year when the new addendum to the Code comes out.
-Christine
Mike
What is your alternative?
Fe
Alternative? Good quality canned software.
Mike
