Orifice Plate Sizing
Does anyone know of an equation to calculate the diameter of an orifice in a thin-edged orifice plate for a particular K-value (loss coefficient)? In particular, for water or slurry duties.
Thanks in advance,
jbag
Thanks in advance,
jbag
RE: Orifice Plate Sizing
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
You can load down calculation programs for free both for single orifice (blende) and multi orifice (lochblende) plates from the source below, with full background for calculation formula and data, but unfortunately only in the german language, and for water....
go to www.erhard.de then select english, downloads and calculation programs.
bk
From Crane Technical Paper 410
Listen to Zapster if your slurry has any abrasive tendency at all.
Good luck,
Latexman
jbag
Dan
www.eltronresearch.com
Dan's Blog
