hole and arc resolution is poor...
I have inherated a project from a coleague, and the model that I have to work with is quite bothersome to look at. All holes, arcs, etc., show up as polygons or angles. This is very destracting, esp when dealing with parts that contain both fillets and chamfers....Does anyone have an idea?
RE: hole and arc resolution is poor...
Have you tried "Assist", "Options", "Display", and under display resolution set "Arc and Circle smoothness" to 2000 ?
Regards Adrian
use "viewres" command
"yes"
input a numbbe
bigger for smoother
The easiest fix is to set invoke the viewres command...answer yes to fastzooms then set the # to 20,000. This is an old trick for when we caddies had to use 386 computers and they were slow (lower # = faster regens). You can also set the isolines to 16 or higher (if using 3d) but be careful performance will slow down if you go to high!
