Above Ground Pool Foundation
Along my part of the Gulf Coast, it is pretty common to install a fiberglass pool above ground / partially buried when near the Gulf. This installation requires bracing the outerwalls.
I have a client who has asked for a foundation design for this scenario. It has been awhile since I put together a structural foundation design, but I am thinking piles and grade beams. I will have to make considerations for storm wave action and possible wind loading.
Am I over-simplifying the problem, or do ya'll think it is straightforward? Have I overlooked a key issue? Let me know your opinions and experience. I told the client I would let him know tomorrow if we will take on the work.
RE: Above Ground Pool Foundation
Unless somebody here has first hand design experience on the fiberglass pool, without knowing material properties, local soil conditions, I doubt you would get the timely feed backs you are seeking.
If you haven't done similar project for a while, don't rush in, buy sometime to collect adequate information to safe guard yours and your client's interests.
Good luck on your meeting.
The foundation will likely need to be an anchor for the pool and you'll need something for sidewall support. You could form and grout or pour concrete in as sidewall support. Be careful to place slowly so as not to collapse the wall from excess pressure from the plastic concrete.
Excellent points. I forgot the dummy soil theory, which is the key concept for this type of application.
