2nd monitor fatal error.
I have a question. I'm using NX 5.04.1 with MP1 installed on a 64 bit platform with 8 gig of ram.
We just received a 2nd monitor and I have noticed that if you have a file open and you drag a session from one monitor to the other and you move it to fast you end up with a fatal error and are blown out of UG. Is there a setting I've not set some where? The speed you drag has to be fairly slow in order to avoid a fatal error is this normal?
Doc
http://www.goodrich.com
RE: 2nd monitor fatal error.
I don't think so... I've a similar setup, and have never seen that problem.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
I've found it only happens with assembly files but with single components it works fine. SO it seems to be related to file size. If I can't find what is causing this I guess I'm going to have to tell myself to go slow when switching monitors.
Doc
I've also encountered similar behavior. So I just don't do it! The NX modeling screen sits on my primary  screen, and my navigators (undocked) sit on the secondary monitor. I do not "maximize" my NX session to span both monitors.
-Derek
Check out www.spacex.com
There is a setting (in Nvidia) configure independently (dualView)which I use so when you maximize it only maximize in the monitor it resides and not the other. I have done better at not moving from on monitor to the other at a slower pace. I was just curious to if I missed a setting.
Doc
