Z axis Moment of Inertia for L shape
Does anyone know how to calculate the Z axis Moment of Inertia for a L-shape?
Thanks in advance
Thanks in advance
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Z axis Moment of Inertia for L shapeZ axis Moment of Inertia for L shape(OP)
Thanks in advance Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Z axis Moment of Inertia for L shape
Anyway, once you get the product of inertia use varying values of theta (O) in the equation:
Ix(cos^2(O))+ Iy(sin^2(O))-2Ixy(sin(O)(cos(O)) until you get the max value. This is the max I. Then subtract this value from Ix+Iy and this will give you Imin.
The principal moments of inertia for an unsymmetrical shape can be found in "Elements of Strength of Materials" by Timoshenko and McCullough as follows:
Imax/Imin = (Ix + Iy)/2 +/- {[(Ix - Iy)/2]^2 + Ixy^2)^0.5
They can also be found by using a Mohr's circle.
Best regards,
BA
Best regards,
BA
EdR
P.S. Use the same axis location used to get the moments of inertia if you are going to compute the principal values...If not the transfer theorm for products of inertia is Ixy = Icg + xbar*ybar*A
I'm attaching my example calc.
actually it works much like Mohr's circle ... it's easy enought to calc Ixx and Iyy (x^2*dA) then Ixy is just x*y*dA ... plot the two points (Ixx, Ixy) and (Iyy, -Ixy), draw the circle, and get Imax and Imin (where Ixy = 0).
