Sheet Pile (River Training) Wall + Precast Cladding
I am going to design a river training wall which comprises steel sheet pile. The difficult doesn't lie in the design of the sheet pile but in precast cladding to the sheet piles.
Does anyone have a sketch showing how the precast concrete panels fixed to the sheet pile wall?
RE: Sheet Pile (River Training) Wall + Precast Cladding
Suggest you contact MSE panel providers for details of possible attachment schemes - as these are the ones the contractors will actually use.
For a recent job involving soldier piles, I have seen a detail where the panels were connected to the piles as follows:
Short angles would be welded to the piles to attach to tabs cast into the panels (top and bottom of panels). The bottom tab had a pin that got set into a matching hole in the bottom angle. The top tab had a matching hole where a bolt attached to the top angle. This detail required some precision in setting the piling. Other arrangements are possible.
Jeff
