Steel column manufacturers
Our client requires 900mm x 65mm wall thickness columns. These are heavy (appx. 1000 lbs). We require 40 foot columns, ASTM A 500 Grade C.
Any ideas on suppliers for these columns? They will likely be non ex-stock items
Thank you
Thank you
RE: Steel column manufacturers
The project is in the caribbean
http:
thanks for the help. I had a look at the site and it looks promising. thanks again.
