unbalanced delta
unbalanced delta
Hi Guys,
I have an unbalanced delta load. Phase AB 7.7Amp Phase BC 7.7 Amp Phase CA 7 Amp.
The power is also supplied form a delta source.
I have also calculated the vector IAB = 7.08+3i, IBC = 7.08+3i and ICA = 6.44+2.73i
Also IA = - (0.644+ 0.27i)
IB = 0+0i
IC = 0.644-+0.27i
What would be the magnitude of IA, IB, IC ?
(If it was 7.7 Amps in all the three phases the magnitude of current would have been 1.732* 7.7 =13.34Amp)
Thanks for your help.
R
IB = 0+0i
IC = 0.644-+0.27i
R
RE: unbalanced delta
I suspect that you need to rotate IBC by 120° and ICA by 240° to get them to a common reference.
How did you determine IA, IB and IC?
Alan
"It's always fun to do the impossible." - Walt Disney
