Two Flexhead connections off of a cross?
I am doing an add relocate job and was wondering if anyone had any information on running more than one flexhead connection off of a single outlet. I want to attach them to a 1x1/2x1x1 cross with an upright head on the top and a flexhead hose off either outlet. think this bird will fly?
RE: Two Flexhead connections off of a cross?
Additionally just shifting one of the outlets to a new mechanical tee would take some demand off that junction but just a sliver, try that alteration in your calculation if its close.
I would also say to calc it if you were trying to hard pipe 2 sprinklers from a single outlet as well.
Good luck with it.
Travis Mack
MFP Design, LLC
See sketch http://
The correct terminology for the fitting is 1"x1"x1"x1/2" cross and not 1"x1/2"x1"x1". Not meaning to be picky on the fitting but it through me at first.
Travis Mack
MFP Design, LLC
Having to calc it is a foregone conclusion.
If the question is: Is this arrangement possible? The obvious answer is yes. Will it work hydraulically? That will have to be determined by calculations.
Travis Mack
MFP Design, LLC
It's nice to see two guys I respect come to the same conclusion I did. It helps me keep my perspective on what's right or wrong. Thank you.
