Hartman Loop/Optimum Energy Controls
I have been approached about adding control software from Optimum Energy into a project I am working on and was wondering if anyone has any information, thoughts, opinions, etc.
The energy savings they advertise seem to be very optimistic. Adding the system would increase the first cost substantially but they are suggesting it will result in a 40% rate of return and a 50% reduction in plant energy costs. I don't doubt that having a system comprised of well matched all variable speed equipment controlled "perfectly" would result in lower energy costs - of course it would but it this system that perfect and could it really cut the energy costs in half? I don't buy it.
I am not experienced with retrofits and this wouldn't be a retrofit either, so whatever improvement is actually realised I would never know. If this system really cuts energy costs in half and does so with a 40% rate of return, then the choice is a no brainer but does it? Does it even come close?
RE: Hartman Loop/Optimum Energy Controls
The results can never be verified. I would insist on a long list of installed systems complete with owner references that you can contact and documentation of existing and post-installation energy consumption profiles before I even consider putting them on the project.
These numbers just aren't optimistic, I doubt they are anywhere close to realistic. I would take this information with several million grains of salt. Their website quotes 30% to 60% electrical energy savings for some systems. With just a software addition? (And of course VFD's on everything in your system if they are not already part of the system-although I bet those costs aren't part of any economic analysis they do).
It would be interesting to follow up to see if they offer any project references. My money would be against them havings such.
Good luck and keep us informed.
EEJaime
This is a packaged software version of the hartman loop which only works on all variable speed plant. You have to have the plant to go with the technology. They install a tridium based box to take over the system control, spend a week commissioning and let it go.
I'd like to hear also if anyone out there has installed one of these and what the results were.
I know if I owned the rights to a product that gave a 50% savings in energy costs, I wouldn't sell it for a price that would allow a 40% rate of return. Why not limit your business exclusively to performance contracts and make a killing?
The web site doesn't have any of the obvious snake oil signals.
I could see some nice reductions in demand charges with the right (wrong?) utility rate structure.
They can save 50% of the energy cost in plants that have bad controls, bad operators, or improperly sized equipment.
On a new plant the NPV is tougher to justify, since you don't really know what the play is going to do in the real world.
If you have a wide varying load profile, I would seriously consider them. We didn't end up buying there software because we had a pretty constant load profile, however I was pretty impressed.
Zuccus
Kevin, I work in Texas, but I'm sure whoever you're working with will provide references, case studies and a more thorough review with our Director of Engineering, Ben Erpelding, to address your concerns.
With new consruction, we usually use the Savings by Design calculations (without using the Optimum Energy software) as the baseline and then compare the actual consumption to determine savings (kWh and $$).
As for the "getting rich doing Performance Contracting" issue: Optimum Energy is very clearly positioned as a software solution. With so many buildings in the U.S. with centrifugal chillers, why limit this technology to a handful of projects that operate under performance contracts?
To address the comment about VFDs and whether they are included in Optimum Energy's economic analysis...in fact our initial savings analysis does include the entire project costs (estimates for work outside of our scope, controls programming, equipment upgrades, engineering if needed, 30% markup, taxes and contingency). No miracles here...just sound engineering that is swiftly commissioned and measured and verified for a minumum of 1 year after installaton.
I'm sure I'll get a chance to look into it further sometime in the future and look forward to it. Since posting I've talked to some people about the system and actually found that a close acquaintance of mine in San Diego has been in touch with Ben and said good things about the system based on what he knows and has heard. Still the 60% savings raises my eyebrows and I have to assume savings of that magnitude are based on a poorly managed system, but overall based on discussions I've had I haven't been able to find anyone with anything bad to say (or anyone that swears by it). But like I said previously, I can't argue against it and the theory behind the Hartman Loop seems solid based on my own understanding. Being a design engineer and not a facilities guy though makes it difficult to fully appreciate the things going on at that end. Just thought I would end the thread with that – I have nothing negative to say but would still like to know more. Any Chicago area installations?
-Kevin Caho
kevin.caho@gmail.com
