Circuit breaker poles in series connection
Circuit breaker MFG application guide allows the usage of three pole AC molded case CB for DC circuit, and recommends connection of all three poles in series. This connection is very specific: the load side of pole 1 is connected to the line side of pole 2, and the load side of pole 2 is connected to the line side of pole 3. This requires to run wires around the CB.Why not to connect load sides of poles 1 and 2 (short jumper) and line sides of poles 2 and 3 (another jumper)? The MFG technical support insists on usage of their configuration with no explanation. Again, this a DC application (isolated from ground). Could this (MFG) configuration be dictated by arc suppression capability (I mean the same direction of the current for each pole is required)?
RE: Circuit breaker poles in series connection
