exporting to pdf in NX 6
On our company we have 12 ug licenses mostly running on XP 64 machines and some on XP 32.
On 2 of these machines we can export to PDF, on the others we can not. The configuration of NX is identical on all of them.
Please can Anyone tell me what is the problem
RE: exporting to pdf in NX 6
I've seen an issue, which may or may not be similar to what you're having - if you have a dual-panel display setup, and you're running NX6.0.1 MP1 or lower (I think) on the secondary display, export to PDF did not work.  I can't be absolutely positive but I * think * that 6.0.1 MP2 fixed this problem.  Also, placing NX on the primary display also seemed to fix that particular issue.
Thanks for your tip, but we are not running NX on dual display machines.
When we try to export to PDF, everything looks fine until the box telling that it's creating de PDF file appears and disappears almost immediately without creating the file.
Anything in the NX log file at that point that might lead you to the problem?
Those symptoms may be coincidentally similar to what I've seen happen with write access problems elsewhere in the past. By all means try to run the same procedure logged in as an administrator user. If that works then you have your solution in waiting you just need to figure out what it is that the user needs write access to and the above post which points you at the log file should help with that.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
What are you trying to export? When we make PDF's where I work we use a free PDF printer (the one we use is called CutePDF) but I'm sure there are a fair few freeware programs out there
Thanks for all your replies.
We use FreePDF_XP and it works fine, it's just that it's easier to use the NX export function.
It's not a question of loggin in as administrator because the outcome is always the same - no file.
To add to the problem, one of the machines that did not export, yesterday started exporting and we haven't changed or installed anything.
Further down you'll find a part of the syslog file where we try to export to pdf without any results.
&MACRO MENU, 0, UG_FILE_EXPORT_PDF UG_GATEWAY_MAIN_MENUBAR !
UNDO_UG: Recyclable status of mark 1876  set to False
Teamcenter Integration: capability NX_Routing_Support is disabled
&MACRO ASK_ITEM 393216 (1 MULT 0) = 0  ! List
&MACRO ASK_ITEM 393216 (1 MULT 0) = 1  ! List
&MACRO      POSITION = 0 "Current Display" ! Index/contents of selected item
&MACRO ASK_ITEM 4128768 (1 BOOL 0) = 1  ! Append to PDF File
&MACRO ASK_ITEM 4128768 (1 BOOL 0) = 0  ! Append to PDF File
&MACRO ASK_ITEM 5832704 (1 REAL 0) = 0.0000000000000000  ! Scale Factor
&MACRO ASK_ITEM 5832704 (1 REAL 0) = 1.0000000000000000  ! Scale Factor
&MACRO ASK_ITEM 6422528 (1 REAL 0) = 0.0000000000000000  ! X Dimension
&MACRO ASK_ITEM 6422528 (1 REAL 0) = 8.5000000000000000  ! X Dimension
&MACRO ASK_ITEM 6619136 (1 REAL 0) = 0.0000000000000000  ! Y Dimension
&MACRO ASK_ITEM 6619136 (1 REAL 0) = 11.0000000000000000  ! Y Dimension
&MACRO ASK_ITEM 7602176 (1 BOOL 0) = 1  ! Add Watermark
&MACRO ASK_ITEM 7602176 (1 BOOL 0) = 0  ! Add Watermark
&MACRO ASK_ITEM 8192000 (1 BOOL 0) = 1  ! Export Raster Images in Drawing
&MACRO ASK_ITEM 8192000 (1 BOOL 0) = 0  ! Export Raster Images in Drawing
&MACRO ASK_ITEM 8388608 (1 BOOL 0) = 1  ! Export Shaded Geometry as Wireframe
&MACRO EVENT FOCUS_IN -10 0, 3866624, 0, 0, 0!
&MACRO ASK_ITEM 3866624 (1 STRN 0) = "E:\AA.pdf"  !
&MACRO DIALOG_BEGIN "Export PDF" 0 ! Special
&MACRO BEG_ITEM 393216 (1 MULT 0) = 1  ! List (Items selected)
&MACRO BEG_ITEM 1835008 (1 OPTM 0) = 0  ! Create New
&MACRO BEG_ITEM 2031616 (1 STRN 0) = ""  ! No Title
&MACRO BEG_ITEM 2424832 (1 MULT 0) = 0  ! List (Items selected)
&MACRO BEG_ITEM 3866624 (1 STRN 0) = "E:\AA.pdf"  !
&MACRO BEG_ITEM 4128768 (1 BOOL 0) = 0  ! Append to PDF File
&MACRO BEG_ITEM 4718592 (1 OPTM 0) = 0  ! As Displayed
&MACRO BEG_ITEM 5177344 (1 OPTM 0) = 0  ! Standard Widths
&MACRO BEG_ITEM 5636096 (1 OPTM 0) = 1  ! Scale Factor
&MACRO BEG_ITEM 5832704 (1 REAL 0) = 1.0000000000000000  ! Scale Factor
&MACRO BEG_ITEM 6225920 (1 RADI 0) = 1  ! Inches
&MACRO BEG_ITEM 6422528 (1 REAL 0) = 8.5000000000000000  ! X Dimension
&MACRO BEG_ITEM 6619136 (1 REAL 0) = 11.0000000000000000  ! Y Dimension
&MACRO BEG_ITEM 7405568 (1 OPTM 0) = 1  ! Polylines
&MACRO BEG_ITEM 7602176 (1 BOOL 0) = 0  ! Add Watermark
&MACRO BEG_ITEM 7798784 (1 STRN 0) = ""  !
&MACRO BEG_ITEM 8192000 (1 BOOL 0) = 0  ! Export Raster Images in Drawing
&MACRO BEG_ITEM 8388608 (0 BOOL 0) = 1  ! Export Shaded Geometry as Wireframe
&MACRO BEG_ITEM 8585216 (1 OPTM 0) = 3  ! High
&MACRO BEG_ITEM 9371650 (1 BOOL 0) = 1  ! Preview
&MACRO OK -10 0 ! OK Callback
&MACRO DIALOG_BEGIN "Persistent Dialog" 129005 ! Persistent
&MACRO DIALOG_PERSISTENT_END 129005
&MACRO FOCUS CHANGE IN 1
&MACRO END_ITEM 393216 (1 MULT 0) = 1  ! List (Items selected)
&MACRO END_ITEM 1835008 (1 OPTM 0) = 0  ! Create New
&MACRO END_ITEM 2031616 (1 STRN 0) = ""  ! No Title
&MACRO END_ITEM 2424832 (1 MULT 0) = 0  ! List (Items selected)
&MACRO END_ITEM 3866624 (1 STRN 0) = "E:\AA.pdf"  !
&MACRO END_ITEM 4128768 (1 BOOL 0) = 0  ! Append to PDF File
&MACRO END_ITEM 4718592 (1 OPTM 0) = 0  ! As Displayed
&MACRO END_ITEM 5177344 (1 OPTM 0) = 0  ! Standard Widths
&MACRO END_ITEM 5636096 (1 OPTM 0) = 1  ! Scale Factor
&MACRO END_ITEM 5832704 (1 REAL 0) = 1.0000000000000000  ! Scale Factor
&MACRO END_ITEM 6225920 (1 RADI 0) = 1  ! Inches
&MACRO END_ITEM 6422528 (1 REAL 0) = 8.5000000000000000  ! X Dimension
&MACRO END_ITEM 6619136 (1 REAL 0) = 11.0000000000000000  ! Y Dimension
&MACRO END_ITEM 7405568 (1 OPTM 0) = 1  ! Polylines
&MACRO END_ITEM 7602176 (1 BOOL 0) = 0  ! Add Watermark
&MACRO END_ITEM 7798784 (1 STRN 0) = ""  !
&MACRO END_ITEM 8192000 (1 BOOL 0) = 0  ! Export Raster Images in Drawing
&MACRO END_ITEM 8388608 (0 BOOL 0) = 1  ! Export Shaded Geometry as Wireframe
&MACRO END_ITEM 8585216 (1 OPTM 0) = 3  ! High
&MACRO END_ITEM 9371650 (1 BOOL 0) = 1  ! Preview
&MACRO DIALOG_END -2, 0 ! Export PDF: OK
UNDO_UG: Recyclable status of mark 1876  set to True
&MACRO MENU, 0, UG_SEL_EDGE_PRIORITY UG_GATEWAY_MAIN_MENUBAR !
&MACRO FOCUS CHANGE OUT 1
thanks
Log file looks just like mine that works.  Have you tried using the Windoze search for *.pdf files created in the last day?  Before the Export to PDF was an option in NX, I would write postscript files out using the Plot function and then I would Distill those into a PDF file with Adobe Acrobat.  I never could figure out why, but even though I would specify the folder where to export the *.ps file to, it would always end up putting it in a temp folder under my account somewhere instead.
Thank you for your reply but NX does not create the file. We can tell if the file is created by the time the message that the system displays saying it is creating the file remains on the screen. It takes some time when the file is created and it is not it disappears almost immediately.
thanks for all your help
