supress errors or warnings.
Hi, i'm building a small application in ansys that generates a geometry parametrically.
I'm using aovlap to see if two areas have an intersection and they don't just touch. The problem is that an error is generated every time that the command fails. If the command fails, i can catch the error it from TCL/TK and i know that the areas do not intersect, but, i don't want the error window to appear.
¿any ideas?
¿any ideas?
RE: supress errors or warnings.
You can check any errors at any time by file->list->error file.
/UIS,MSGPOP,4
Suppresses error message pop-up dialog box. (Error messages will still be recorded in the jobname.err file and output window/file.)
Another question that i have, is that i need to calculate some areas. But, every time an ASUM a window with the information about areas, moments of inertia, etc appears. I just want to calculate the area, not the window to appear.
