List system options
List system options
List system options
Does anyone know if you can print a list of your system options and document properties?
RE: List system options
Do you really need a print? What is it's purpose?
I don't know of a single click method. You could do a series of screen captures of each page, or you could also use the Copy Settings Wizard to create a .reg file which could then be printed via Notepad.
I'm looking at having a list of the settings with their current values.
This will help us quickly check that systems on different sites and contractors we use all have their machines set the same.
One of the reasons the Copy Settings Wizard exists is to create a file which can be imported to other machines.
Copy settings wizard can just copy system settings.  Tool bars, short cuts etc would be left alone but I believe it would change template, toolbox etc locations so that might be a draw back.
Grant
Applications Engineer
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
Quote (SW Help):
The Copy Settings Wizard saves, restores, and propagates system settings to users, computers, or profiles.
When you select options for the SolidWorks software, those settings are saved in a registry file, and the software recognizes the settings from one release of SolidWorks to the next. For most users, no action is necessary to maintain their settings. However, you can use the Copy Settings Wizard to distribute settings.
You can Save or Restore system settings for:
Keyboard shortcuts
Menu customization
System options
Toolbar layout (All toolbars or Macro toolbar only)
