ASME IX- SWPS
ASME IX- SWPS
ASME IX- SWPS
What is the code concept?
it require PQR or not? (like AWS Prequalified)
thank for any help..
RE: ASME IX- SWPS
Standard Welding Procedure Specification (SWPS) is provided by AWS for nominal cost, and is a pre-qualified welding procedure specification. It does not require a WPQR.
RE: ASME IX- SWPS
We confuse that why ASME required demonstration, if demonstration it will like you do the PQR.
RE: ASME IX- SWPS
Because if you are going for ASME stamp certification, you need to demonstrate all aspects of your written Quality program and that includes welding.
RE: ASME IX- SWPS
See Article V of ASME IX.  The concept is similar to prequalified AWS procedures.  However, there is still some mechanical testing or alternative RT required by ASME.
See Mandatory Appendix E for the approved list of materials/welding processes.
