Can't delete <DIM> tag?????
I wasn't paying attention, but when I wanted to delete the <dim> tag to override the dimension...the alert box pulled up, but as mention I wasn't paying attention and keep typing away with what I wanted to override it with...well I must have agreed to something, because I cannot delete the <dim> tag at all....I assume I checked/un-checked something in the options area...but I can see it to save my life....anybody have a clue on this??
RE: Can't delete <DIM> tag?????
I'm guessing you clicked the "don't show again" box.  Unfortunately, that one only lasts for the current SW session.  I'll bet you may have already figured this out, but all you need to do is restart SW.
-handleman, CSWP (The new, easy test)
OMG...How simple was that....I knew that is what I check...but I have always thought that was only for that one command instance, not the session...so I was going mad trying to find the option that was altered (thinking there was one)
