Can spring loaded suction valves be used in place of wave valves?
I have an older model york recip compressor that needs valves. It is a js43 compressor with cage valves. The original set up had wave style valves, concave and warped from the factory. The only replacement parts i am able to buy within my budget are spring loaded. JCI will not give me any info as to whether they are compatible. Does anybody know if these 2 assemblies can replace each other?
