Pump "Clones" such as the 2196 vs. Goulds 3196?
what kind of experiences, good or bad?
do spares really interchange between the two?
example would be the Summit 2196 vs. a Goulds 3196.
http://www.summitpump.com/s2196ansi.htm
tia, ben
tia, ben
RE: Pump "Clones" such as the 2196 vs. Goulds 3196?
Generally speaking, the fit and quality of the OEM parts is better, and you'll (probably) get better support with the OEM. If you add pirate parts into the mix, you'll probably get zero support from the OEM.
