Fortran subroutine - global variable
Hi everybody,
I have made a heat source to model laser welding with the dflux subroutine and I would like to know, if it's possible to define some global variables.
What I am trying to accomplish is to adapt my heat source if for example any point of the model reach a defined temperature. Is that possible?
Thanks in advance!
RE: Fortran subroutine - global variable
You should be able to hard code your limiting value into your Dflux routine.
I am not too familiar with user defined subroutines but I think Depvar's are global (in the sense of the material anyway). Maybe that is what you need to define, then have your subroutine grab them when needed.
HTH
Hey, I am glad to read some ideas:
To vumat721: your solution could work if I am able to get the temperature of a determined node. In this case, I would able to define the behaviour of the routine with the limiting value, in my case the temperature of the node (hard coded).
To DanStro: I didn't know of the existence of Depvar, I have to look at the documentation but sounds promising. I will give it a try too.
Thank you very much for the Ideas, let's see what comes next :P
Depvar is used to specify number of state variables (statev) within a material subroutine (i.e UMAT, VUMAT, etc). I don't believe that DFLUX lets you have these kinds of state variables.
DFLUX gives you the temperature at the integration point. Perhaps you want to use UTEMP instead of DFLUX?
Hi vumat,
I finally found the way to accomplish that. In fact, it's possible to define global variables within a subroutine. I don't tried yet but I think you can exchange variables between subroutines with this "global variables" as well.
The solution was to read a Fortran Manual, also, in my example:
*USER SUBROUTINES
    SUBROUTINE DFLUX(FLUX,SOL,KSTEP,KINC,TIME,NOEL,NPT,COORDS,
    1 JLTYP,TEMP,PRESS,SNAME)
C
    INCLUDE 'ABA_PARAM.INC'
C
    DIMENSION COORDS(3),FLUX(2),TIME(2)
    CHARACTER*80 SNAME
    parameter (BoilingPoint = 2792)
    real maxTemp,depth
    COMMON /Control/maxTemp,depth
C###########################################
C Coordinates
        x=COORDS(1)
        y=COORDS(3)
        z=COORDS(2)
C  Coordinate conversion
        r = sqrt(x ** 2 + y ** 2)
C Variable to store the temperature of the element. It will be used
C to check the max temperature of the Model.
      tempmaxtemp = SOL
C If Statement to calc the max temperature in the Model
      if(tempmaxtemp.ge.maxTemp)maxTemp=tempmaxtemp
The variable maxTemp don't lose the value, also, global variable. With this method, I can know the max temperature of my Model.
Anyway, thanks for the help!
Sounds good. I know Abaqus used to warn about using common blocks with subroutines. I don't remember the details, but maybe it's only an issue if you do a multi-cpu job? It looks like you can use "UEXTERNALDB" if you ever run into a problem with the common block not working as expected.
