Lintel retrofit
Lintel retrofit
I have a small retrofit project. I have been hired to work on a small reno project on an existing building. My end of the project is designing a lintel to support a new wider opening in a CMU wall. The existing door will be removed and the opening will be widened to approx 10 feet.
Anyway, I planned on using steel angles (One on each side of the wall) to support this new opening but they are looking for other options. I have only worked on a couple of other retrofits before and was wondering if there was an "industry standard" for this situation or if its usually just up to the designer?
RE: Lintel retrofit
How do others do it?
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
RE: Lintel retrofit
RE: Lintel retrofit
Mike McCann
MMC Engineering
RE: Lintel retrofit
RE: Lintel retrofit
The angles bear 8" onto solid masonry at each jamb, of course.
DaveAtkins
RE: Lintel retrofit
I agree with the ease of the double angles as I have specified it before but if they want a plain rendered look then precast concrete gives a better finish.
