Shrinkage of PA6 30GF @ 5mm
Hi all,
We are currently having a tool made for a product with a tolerance of +0/-0.5 over 197mm. Wall thickness 5mm.
Du Pont only have the shrinkage data for 2mm thickness (Doh!).
Some material manufacturer's have info on shrinkage vs wall thickness, but as usual,I cannot find amongst my data heap.
I anyone has info would be appreciated.
Material is Zytel 73G30T (PA6)
Cheers
Harry
Cheers
Harry
RE: Shrinkage of PA6 30GF @ 5mm
I have some data on Akulon K224G6 at 4mm section thickness before and after moisture conditioning to equilibrium at 23 deg C and 50% RH and some data on Durethan BKV30 at various thickness before and after conditioning, but it may lead you astray more than it helps I will try to scan it tomorrow.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Cheers Pat.
The T makes no diff according to D-P data sheets at 2mm, so I guess it's effect is minimal.
Sounds good info there - better than zilch!
Harry
www.tynevalleyplastics.co.uk
