Thickness for slab supporting mechanical Turbines
I was working on design of mechanical room on second floor which supports a heavy mechanical turbine pump. I wanted to know if there is any minimum thickness required to support the heavy turbines.(>100k load)
RE: Thickness for slab supporting mechanical Turbines
For both cases, check required thickness to resist punching shear induced by weight & impact, without the help from reinforcing steel.
