3d cad files for sanitary/tri clamp fittings from 1/2"to 6"
This is a question I posted here in 2007 and to this day still have not found a good answer. I am looking for 3d files from "Bradford" and "Alfa Laval" specifically or ones that use the same dimensional standards. These fittings are the "tri clamp" design and butt weld type typically used in food or phamaceutical production. I have found single downloads of various parts but one at a time for each and every variation is a real chore. And the ones from "Swagelock" for instance are dimensionaly different so they do not solve my problem without reworking every file. Does anyone have a direct lead on a complete set of files for these? As you can imagine I have been to all the manufacturing and distribution stes I can dream up over the years but with no luck. I have translators so I don't care what they are in as long as it is 3D. You don't know how much fruitless time I have in this search so anything of worth would be greatly appreciated.
