Minimise heat loss during internal insulation
Hey,
We are vessel fabricators and have the vessel made of carbon steel. Customer wants internal insulation rather the external.
Because of the grid supports being welded directly to the vessel, (as shown in the attached figure), there will be heat loss through grid support.
Is there any way of minimising the heat loss ?
One way which I could think of was to use 'thin stainless steel supports' and weld them to c/stl vessel. Again with PWHT and sigma phase, customer is not willing to go with
st. stl and do not want external supports.
I am stuck and would be happy if anybody can advise or had similar problem on vessel.
RE: Minimise heat loss during internal insulation
gr2vessels
I mean using tray, can there be heat passing through trays ?
Now, check first the weight of the selected insulation, then work out the load on the supports, design and fabricate an insulation supporting structure, drill the new holes, bolt on the internal insulation panels, close the column, go to the control room and press the start button. Simple.
cheers,
gr23vessels
PS. This internal insulation sounds to me very similar to the elbow grease...
If it is, the sulfuric acid converter towers I've worked on long ago used a brick lined lining with built up/moulded brick tray supports. Alternatively, you could lined your steel tray support with refractory to insulate it.
