import part and rotate it 90 degrees
I'm trying to import a sketch in a part. Unfortunately this import is on a 90° angle with the original part. Now, in NX3 I could use transform to rotate it. It would ask to transform parents too, I would select OK and that was it.
But in NX6 Ctrl-T does not have this rotate feature anymore. And the Move Object command in the Edit Menu seems to work, but when I click OK it says it can not do it and then reverts to the pre-state.
I'm using NX over 3 years now, but it can be such a time waster on those simple things. You'll never seem to be able to learn something and then do it faster the next time, as with normal things in life.
RE: import part and rotate it 90 degrees
use the search on this forum ... this was discussed allready
Use NX 6.0 Move Object.  Just go to the Settings section and toggle ON 'Move Parents' and toggle OFF 'Associative' and you will get exactly what you got using NX 3.0 Transform.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
@John
Thank you x 1000!
Another option would be to rotate the CSYS in the source part file first, then export the sketch to a new part.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
