Solkor summation transformer component
Can anyone tell me the purpose of the capactitor in the drawing of a Reyrolle SOLKOR A summation transformer below
[IMG]http://i7.photobucket.com/albums/y251/efiste2/a1.jpg[/IMG]
RE: Solkor summation transformer component
I think the cap is provided in order to reduce the reaction time of the pilot wire by decreasing the reactance. [Time=k*X/R]
It's part of a tuned circuit designed to give a peak response at the power system's fundamental frequency and suppress response at harmonic frequencies. There's some explanatory notes in the IEE book "Power System Protection Systems & Methods" - luckily Google has it as a preview to save you buying it! Here's the Link.
If David Beach happens to be reading this, this is a book which is worth adding to the FAQ.
Scotty,  Things are a bit hectic at the moment.  If you could send me a reminder through the FAQ comment I would appreciate it.  Thanks.
David,
'Tis done!
Thank you, Scotty. From the "link" it is clear that is a pass-high filter.
