Completely lost with animations!!
Hey all,
trying to make animations with solid works 2007, and i just cant get it to work. I know im prob doing something real silly as I havnt much experience with solid works but heres my problem.
Iv added on the animator using add ins and can create animations using the wizard but when creating my own it just dosnt seam to work.
I move the object, drag the time bar as instructed, the time moves but the object just stays in original position (regardless how rotated or moved) when played.
I did it once in college and remember we had to turn something on/Off just not quiet sure what. sorry for silly question but its wreaking my head
would be so grateful for any help
Cheers
Cheers
RE: Completely lost with animations!!
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
Normally SWX is superb for its help files, but using the Index section of their help and looking for items related to Animation or Motion yielded surprisingly little. However, if you go to the general help and the Search tab you should look for "Animation Wizard" and "Basic Motion Overview". For newbies this should be a very good start.
If you have SWX Premium there is a tutorial for SWX Motion.
Hope this helps.
- - -Updraft
When you put your timeline where you want it, copy the last key for the component (CTRL-C) where it was last placed, paste it on your current timeline (CTRL-V). Select the new point you placed, and while the point is selected, move your part. This updates your key to the new position.
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
