Mat foundation
Mat foundation
Dear All
how we can calculate bearing pressure of mat foundation of size 100m x 125m
RE: Mat foundation
Is it rigid or flexible? The stiffness of the mat will make a difference. If rigid, the edge bearing pressure will be higher than that at the center. If flexible, the bearing pressure will be the same at all points. Suggest you look at Poulos and Davis' Elastic Solutions for Soil and Rock Mechanics - Chapter 7, here: http://www.ce.ncsu.edu/usucger/PandD/PandD.htm
Jeff
RE: Mat foundation
RE: Mat foundation
