Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I always seem to find what I need in previous threads without starting my own. I have started a couple but that's it..."
Geography
1wise (Aerospace)
27 Mar 09 10:19
I'm having a nightmare turning this Material (Hast B) without getting the "Orange Peel" effect. Does anyone have any Magical explanation on how to reduce the visual effect of this orange peel? Perhaps SFM or tools?
arunmrao (Materials)
27 Mar 09 22:34
"Machining Nickel Alloys"  . A Nickel Development Institute reference book, Series N 11 008
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
saberblue (Industrial)
28 Mar 09 18:00
This type of "orange peel" damage if often caused by excessive heat building up in at the point of cut -- some times a very heavy duty soluble oil or straight oil to reduce rubbing friction can do wonders -- you will need a fluid with maximum hydrodynamic lubricity - EP lubricity will probably not be effective
A.R. "Andy" Nelson
Engineering Consultant
anelson@arnengineering.com
1wise (Aerospace)
30 Mar 09 7:32
Thanks for the reply,
I've try many ways to avoid the "orange Peel" I've taken very light cuts even tried cutting .003" and still get the same thing. I also tried cutting with oil to no success I'm starting to think that it's just the Material.
SincoTC (Mechanical)
30 Mar 09 8:04
Not had any experience with Hastelloy, but I've often found "orange Peel" is caused by edge rubbing and tip dulling, especially on light cuts and found that a smaller tip radius on the insert helps minimise this.
TVP (Materials)
30 Mar 09 8:19
Have you reviewed this information from Haynes, the producer of Hastelloy?
http://www.haynesintl.com/pdf/h2010.pdf
The others have identified the issue: too much heat generated by a dull tool.  Are you using carbide inserts?  A premium oil-based lubricant that is formulated for nickel-based alloys?  Have you discussed your application with one of the insert manufacturers like Seco, Valenite, Sandvik, etc.?  The latest generation coated carbide tools are significantly better at retaining a sharp edge, and with proper tool setup, the heat should go with the chip, not remain in the workpiece.
1wise (Aerospace)
31 Mar 09 13:47
Thanks for all the tips. . . I will follow through with all.
dicer (Automotive)
11 Apr 09 1:04
Sharp and very stout setup is what you need. Don't push it. Slow.
secotools (Mechanical)
22 Apr 09 16:40
Hi there,my name is Kevin Hanson,Im english but have been living in holland for the last 28 years.The problem your having is a combination of heat build up in the cutting zone,another thing could be that the coolant is not oily enough.Cant think of the english word,I mean make the % as high as possible.What works really well on the super alloys is the Jet Stream Tooling from Seco Tools in combination with the new aerospace grades.I have some customers that turn alot of this material and also Inconel 718.The results that you can achieve with this a fantastic.   I,m a cutting technology engineer for Secohier in Holland.regards Kevin.
silveringchap (Mechanical)
26 Aug 09 17:46
If I remember rightly about this material, you have to use carbide tips for alloy steel and when you machine it, never dwell or the material starts to harden i.e machine it like you mean to, dont mess with it.Also, slow down as this stuff seems to toughrn off if you get it too hot.
27 Aug 09 4:24
hi 1wise.like said it could be a problem with the material itself but I dont think thats likely.I machine a lot of super alloys when doing tests and troble shooting here in holland for Seco Tools.You should really use sharp very positive inserts.PVD micro grain inserts.
mfgenggear (Aerospace)
27 Aug 09 15:20
what is the machine, feed & speeds?
what type of coolant/
what type of holder & inserts.
I use to work with this stuff it does not not like small
feeds rates & depth of cut. Work Hardens like hell.
.015 min depth of cut when finishing.very very slow with carbide, , very fast with ceramic.
.050-.060 or more depth of cut with ceramic inserts.
depending on the rigity & horspower of your machine.
surface feed depends on the inserts.
Recommended from the Machining Hand Book  Volume 1
Annealed or Solution Treated.
Carbide inserts C-2 grade, depth of cut .030, 100 SFPM , feed.005-.007 IPR
Carbide inserts C-2 grade, depth of cut .100, 90 SFPM , feed.005-.007 IPR
highspeedmachinist (Aerospace)
8 Sep 09 20:52
only engage 10% to 15% of the cutter cutting edge to allow it to cool
The trick here is to do the RPM's per the cutters diameter and composition, which determines the surface feet. Then you can go fast as feed will permit and or finish requirement allows. However, only engage 10% to 15% of the cutter cutting edge to allow it to cool. I, myself didn't believe it at first. But I saw it with my own eyes and was amazed.
Close Box
Join Eng-Tips® Today!
Join Us             Close
