Desanding of FWKO and Treater
I have started working on a project that involve desanding of the FWKO and Treater system. I have never worked on such system before although I am quite familiar with treater operation and design and also worked with some FWKO. mostly i work in the gas side. so any comments where can i find information or literature about such operation. our client told us that treater is working at 130 C and during the desanding operation the desanding water will be 91 C which will cooldown the treater and treater outlet oil may go off spec. they are looking for a solution to this problem as well. i think 91 C water is already quite hot as it is coming from a skim tank and i dont think we can heat this water more because skim tank is an atmospheric tank not a pressurized vessel. so i am looking for the solution to this problem. also if some one knows or have some link or any reading material on desanding operation of vessels. please help me. just to let you let you guys know these vessels are AKER vessels and already equippid with desanding pan and nozzels.
RE: Desanding of FWKO and Treater
Desanding is part of the process in oilwell drilling operations. Cyclone separators are used to spin out the sand. They can be used in batches or a single large unit, Sizing of the unit is of course dependent on flow rates.
Offshore Engineering&Design
