Error while saving : Unable to save model. Correct problem and try agn
When I try to save a pretty huge model, I get the following message :
Unable to save model : Opération réussie.
Correct problem and try again.
"Opération réussie" means "Operation successful" in french.
Sure UGS developpers have humour...
What can I do ?
Thank you in advance
What can I do ?
RE: Error while saving : Unable to save model. Correct problem and try agn
You can also try "Save As" to get a new free file. Losing the model is usually bad news.
So, Good Luck
Thomas
I also tried to "Save as" but in vain...
Can anyone help me please ?
Julien
Otherwise I agree with rb1957, try an export.
Also, is the problem unique for this model or is it all models. Can you test that?
Good Luck
Thomas
Julien
Thomas
Could it be a problem in the compatibility with my OS ? I have got Femap Nx Nastran 9.2 and an XP SP2 64 bits 2003.
And also, what does a rebuild consist in exactly ?
Julien
If I go on working on my model, I get the following error :
Unable to allocate memory to save graphics.
Close other applications, add real or virtual memory. For animations use fewer frames or a smaller window.
The problem occurs when reaching approx. 1.5 Go of virtual memory. I allocated 20 Go, but in vain. It is like Femap cannot "see" the whole virtual memory.
Again, thanks for your support.
Julien
As for "save graphics", I've had that problem but never so that it made saving impossible.
When you run a 64 bit system, how much ram do you have installed?
I think you should check the manual for memory settings. That might be the problem. The graphics error I have seen om my laptop(2 GB ram) but never on the workstation (16 GB ram).
Finally, when you say "huge model", how many nodes/elements are there?
Thomas
There are about 1,500,000 nodes and 700,000 elements.
Julien
I don't know what the problem can be. On my laptop I have workewd with models up to approx 1 million nodes/elements.
If it is just this model its probably something in that model. Otherwise I don't know.
Sorry
Thomas
