Alternate welding method for stud welding
Hey folks,
Just looking for some input on using an alternate method of welding studs to plate other than 'conventional' stud welding.
I am assuming that the stud can only be a mild steel which will limit its structural performance if it is welded to plate via a complete pen weld by pencil point or chisel point prep.
The original planned stud was a M16 Nelson stud which is comparable to A325.
thanks
DRW
thanks
DRW
RE: Alternate welding method for stud welding
Dik
htt
http://www
Friction welding is technically possible, but is usually limited to joining axisymmetric components. You may want to review the websites of manufacturers like MTI Welding or Thomson for more information:
http://www.mtiwelding.com/
http://www.thompson-friction-welding.co.uk/
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
